ScarletMarisa37's avatar
ScarletMarisa37
Hub 4 acting weird in Router Mode
Hi, 2nd post on here, but this time, it's my Hub 4 being completely weird, the only thing in my whole house connecting is the downstairs tv via ethernet, all the rest are WiFi, My brothers phones and laptop, my ps5 and PC and my phone are all failing to connect to the main router, everything was working perfectly last night, but now it's not, having to use Mobile Data to make this, tried resetting it, same problem, can't it be reset on Virgin's end?
  • Tudor's avatar
    Try a pin-hole reset of the hub.
    • ScarletMarisa37's avatar
      ScarletMarisa37
      I've already done that as mentioned in my first comment, Everything was working last night, and now it's just randomly stopped working, tried all day to get the thing to work
    • Akua_A's avatar
      Akua_A
      Hi ScarletMarisa37
      Welcome back to our community forums and sorry to hear you were having issues with your hub 4 in router mode. We can understand the inconvenience caused. Can you confirm that your service is fully up and running again? Do you need any further help with this?
        ScarletMarisa37
        Yes, I can confirm everything is now working, I went through the maintenance thing to try and fix connection issues, and it worked, sorry to put stress on you, I should've done the connection thing first before commenting here, my bad
    "it was working before I cleaned behind the tv"
    Check all the VM coax cables are firmly secured from the wall socket to all of your VM kit.
