gilbo2's avatar
gilbo2
Dialled in
Hub 3 ip range?
Do the latest Hub 3’s allow you to change the LAN ip range?
(just signed up to M125 so assume this is what I’ll get)
  • legacy1's avatar
    nope you need your own router
    • gilbo2's avatar
      gilbo2
      Dialled in
      Thank you, I feared as much.
      Do any of the VM hubs allow the ip range to be changed?
      • nodrogd's avatar
        nodrogd
        On the residential service, no. I think the ones supplied for Virgin Business services do.
    For about £40 or less a TP-LINK Router is available from Amazon with decent Wi-Fi and all 1Gb/s LAN & Network ports.
    • gilbo2's avatar
      gilbo2
      Dialled in
      I'll take a look at those, thanks. I don't need Wi-Fi as I have BT Whole Home discs, so I'll maybe find something even cheaper, or take the Wi-Fi as a bonus 🙂
    Make quite sure ( do not assume) the BT Whole Home discs are a full retail product that you can re-configure to work with another ISP.   A Wi-Fi Router is a bonus ... it gives you one more Wi-Fi AP in your home.
    • gilbo2's avatar
      gilbo2
      Dialled in
      Good point, they are supposed to work with any ISP but will check first.
  • I believe not, but you can use the reservation feature to reserve specific IP addresses to specific devices, identified by mac address.
