Mike_R3's avatar
Mike_R3
Hub 3 has permanent Red light on
My virgin Hub 3 has had a red light on instead of white for well over a month.  I have tried all the suggestions online such as turning off for 30mins to let it cool down and performing a hard reset but nothing seems to cure it.
The hub is working ok but I am bothered by this in case its not secure or something
Can anyone advise?
    It can be the Hub 3 LED is fading or it can an over temperature fault.
    To check login in to the Hub 3 menu at http://192.168.0.1/   use the numeric HUB PASSWORD from the bottom side label.   ( this is not the Wi-Fi password )
    Run the Network diagnostic tool
    Scroll down through the results and find the Temperature entry.   Is it normal ?
  • Ashleigh_C's avatar
    Ashleigh_C
    Hi there Mike_R3
    Thank you so much for your post and welcome back to the forums, it's always great to have you here.
    I am so sorry that you are facing this issue with your Hub and thank you again for trying all the recommended fixes already. I do think, as these have not worked, it would be best for us to arrange an engineer to come and take a look into this for you. I will arrange this with you via a private message.
    Ashleigh_C
    Hello again Mike_R3
    Thanks so much for your private message and confirming your address, I have now booked you a visit for the red light issue – you can check the date and time via your online account here. If you have any issues with accessing your online account or unable to see your visit, please do let us know and we’ll pop you a message to confirm.
    There will be no charge for this visit unless:
    • The engineer diagnoses the faults as not being caused by our network/equipment
    • The engineer discovers that the fault or problem relates to your equipment
    • The engineer discovers that the fault or problem relates to any system that we are not responsible for
    The engineer will confirm during their visit if any of these instances apply, and if so, a £25 charge will be applied to your account.
    Please ensure there is someone over the age of 18 present at the time of the visit. If you need to change or cancel your appointment you can do this online or via the My VM app by 4pm the day before the appointment.
    If you do miss an agreed appointment for any reason, a £25 missed appointment charge will be applied to your account on the day of the appointment
