samwalby's avatar
samwalby
11 months ago
Permanent red light on Hub 3
I think I need a new router. I've tried turning off and on, pin reset and making sure it's ventilated. The red light is on permanently and the connection is slower than normal and less consistent. Would someone be able to help please?
  • Hi samwalby
    Sorry to hear of your red light concerns. We can see that you has another thread open regarding this that you have already been supported on. We ask members not to create multiple posts on the same issue, that way we can handle your query within one space and save any confusion. This also helps with members look for answers and can find all the steps and advice within one thread.
    Please let us know if you are having any further issues or have any questions at all. We'll be here to help on the Community Forums if needed.
    • Winelist's avatar
      Winelist
      Well yes, ‘should’ be replaced, the issue will be getting anyone to actually do it!
      samwalby
      I'm afraid the forums aren't an instant messaging service and it can take a couple of days before staff respond to your thread.  They generally answer the oldest posts first, so bumping yours by adding further comments moves it further back in the queue.
    • Carley_S's avatar
      Carley_S
      Hi samwalby
