9 months agoAlessandro Volta
It can be the Hub 3 LED is fading or it can an over temperature fault.
To check login in to the Hub 3 menu at http://192.168.0.1/ use the numeric HUB PASSWORD from the bottom side label. ( this is not the Wi-Fi password )
Run the Network diagnostic tool
Scroll down through the results and find the Temperature entry. Is it normal ?
Related Content
- 3 months ago
- 27 days ago
- 4 months ago
- 11 months ago
- 2 years ago
