- AdduxiVery Insightful Person
The red LED on a Hub 3 is the overheating warning. If this is faulty, i.e. on when it should be off, and a pinhole reset does not fix it, then the Hub should be replaced. If you wait here a day or two a VM Mod will pick this up and discuss with you directly.
- Jellis19Tuning in
Tried the pinhole reset but still showing red! Hopefully the VM Mod will be in touch soon.
- Client62Alessandro Volta
Is the Hub 3 hot or not ?
To check login in to the Hub 3 menu at http://192.168.0.1/
use the numeric Hub password from the bottom side label. ( this is not the Wi-Fi password )
Run the Network diagnostic tool
Scroll down through the results and find the Temperature entry. Is it: Normal ? - Vikki_MForum Team (Retired)
Hi Jellis19,
Thanks for your post and welcome back to our community.
We're sorry to hear you have a constant red light on the hub.
If you've done a reboot of the hub, and the light remains, we'll need to replace this.
I'll send you a private message now.
Please look out for the envelope in the top right of the page and pop back to me when you can.
- Jellis19Tuning in
I’ve been trying to respond to the private messages that have been sent but for some reason it won’t allow me to reply. Could someone please contact me again as the red light is still showing on my hub 3.
- Gareth_LForum Team (Retired)
Hello Jellis19.
Sorry to hear you've been unable to send a message.
I will send you a private message now.
If you can check the envelope at the top right of your screen that would be great.
Gareth_L
Related Content
- 4 months ago
- 1 year ago
- 1 year ago
- 5 months ago
- 2 years ago
