SA_78901's avatar
SA_78901
9 months ago
Hub 3 - red light
Hi, like others on this forum I now have a solid red light on my hub 3. I’ve tried all the tips I’ve found (checked connections, reset it, let it cool down, kept it ventilated etc) and it’s still red. How do I fix it/get a replacement please?
    • Lee_R's avatar
      Lee_R
      Hi SA_78901 thanks for posting and welcome back to our community.
      Sorry to hear of the constant red light on your hub 3. And for any concerns it may be giving you. So that I can take a look on behalf, I'm going to send you a private message. Please keep an eye on your inbox in the top right of your screen.
      Lee_R
    If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. It is a potential risk and as such should be managed as such.
    A VM Mod should pick this up and discuss.
