kokoabc's avatar
kokoabc
Just joined
Has anyone got Port Forwarding to work on the Hub 5 when NOT in modem mode.
Hopefully a simple question.....
Has anyone got Port Forwarding to work on the Hub 5 when NOT in modem mode. I have tried everything, though granted their isn't much to try as it's quite straightforward. I used to use this on my Hub 3 then had an upgrade a few weeks ago and cant port forward. Trying to port forward 25565.
  • jpeg1's avatar
    jpeg1
    To be honest, if you can't use the VM Hub just as it comes out of the box, you need to switch it to modem mode and get your own router.
  • legacy1's avatar
    Guess Port Forwarding is broken VM don't support anyone doing it.
