dab8's avatar
dab8
Just joined
18 hours ago
Extending connectivity across circuits
Hi. We have had an extension built and power in the new part of the house is on a different circuit different consumer unit/fuse box.  I’m looking to move my study into a room in the new bit but the WiFi is not completely reliable (maybe due to being on the other side of the old external double skin wall).  What’s the best way for me to do this? I have some dlink plugs to put Ethernet over the mains, but as it’s a different circuit this doesn’t work… and a long Ethernet cable down the corridor isn’t ideal (I have a Hub5). Many thanks Dan
  • Roger_Gooner's avatar
    Roger_Gooner
    It's crazy not to wire the extension as it will cost virtually nothing as you have builders in. Use cat 6 Ethernet cable terminated at an RJ45 wall socket and you can connect to it a 4 or 8-port unmanaged Gigabit network switch if you need multiple ports for a wireless access point, PC, games controller, etc.
  • jpeg1's avatar
    jpeg1
    The only reliable answer will be an ethernet cable into the extension.
    • dab8's avatar
      dab8
      Just joined
      Thanks Jpeg1, I had thought that, just wondered if there was other options…
        +1 for the cable.  However remember cable runs can be external.  Have a think about this and discuss with an electrician if you are not a DIY person.
