Marue1011's avatar
Marue1011
5 months ago
Constant red light
We have a constant red light on our Hub 3. The hub is not hot. We have reset it and turned it on and off. The wifi is ok for a while, then becomes intermittent. Any suggestions….
1 Reply
  • Thanks for reaching out to us Marue1011, and a very warm welcome to our Community Forums!
    Sorry to hear of the issues you've been experiencing with the Wi-Fi issues and the solid red light being present on the hub.
    We will need to issue a replacement hub to you to resolve this issue for you.
    Check out the envelope in the top right hand corner for a private message from me.
    David_Bn
