SerraO's avatar
SerraO
Constant red light
I've had constant red light on my hub for about six months. I've reset my hub several times with the off button and with a pin. It is located in an airy place. The hub doesn't feel warm or hot at all. I checked all the cables and they seem to be fine. The Internet connection is very flaky, even sometimes when I'm right next to the hub. What else can I do?
1 Reply
  • Hey SerraO, thank you for reaching out and we are sorry to hear you are having a red light issue
    Please try these steps'
    • Then use the power switch to turn the unit back on. The Hub should now operate normally.
    We will also send you a DM.
