Dss28003's avatar
Dss28003
5 months ago
Volt not applied
Hi I’m both 02 and virgin customer had upgrade on double data from 02 but been 5 weeks since virgin emailed me confirming upgrade but nothing has happened?
  • Hi Dss28003
    Thanks for posting and welcome to the community. Sorry to hear of this Volt dispute.
    If you were already on a Volt tariff, then you wouldn't get a boost, as you're already on this.
    You can check this yourself in the online account - virg.in/myVM and what does it show on your package?
    Best wishes.
  • Hi thanks for your reply have checked my account and says I’m on a volt tariff I’ve only joined 02 this year and then applied for the volt upgrades which were immediately done on the 02 network.ive been with virgin 3 years on m500 50 plan so why wouldn’t i be entitled to upgrade on broadband?
    • Martin_N's avatar
      Martin_N
      Thank you for coming back to us. To confirm, is the deal you have been on with us already a Volt tariff or not?
      ^Martin
      • Dss28003's avatar
        Dss28003
        Yes it says says volt package but had an email awhile back from VM confirming I was eligible for volt upgrade
