arlowood44's avatar
arlowood44
3 months ago
Ringer not working with incoming calls.
Noticed that we had not had any incoming calls on our landline for over a week. (we usually have at least one potential scam call a day as a rule).
We have a traditional base unit handset that is plugged into a standard copper wire type BT socket.
After further investigation we have established that we have a dial tone and can make outgoing calls. Also all other features of the base unit are working.
We have no ringer sound to alert us to incoming calls. We have arranged for my son to ring us at a specific time and if we pick up the handset we can talk to him normally. He has explained that when he tried ringing previously there was a ringing tone at his end but when we did not answer (no ringer at our end) the phone did not default to the answerphone option.
I have tried reporting this using the 150 number but I was put through the the call centre in India and could not get any real sense of what I should do or how the fault was going to be addressed.
Would appreciate if a Moderator could message me to try to sort this issue.
  • I have the exact same problem, is there anyone out there who can help me. I had to reply to this thread, because i cannot find the 'start a discussion' tab anywhere on this site.
    thanks
    • Akua_A's avatar
      Akua_A
      Hi jagsman411971
      Welcome to our forums and sorry to hear you are having issues with your landline ringer. We can understand the inconvenience caused and want to do our best to help from here. We are sending you a private message to best look into this. Please keep an eye out for an envelope at the top right corner of your Forum page. Let me know if you have any issues locating this.
  • Gareth_L's avatar
    Gareth_L
    Hello arlowood44
    Thanks for your first post and welcome to our community.
    Sorry to hear you've been experiencing issues with your landline over the last week.
    I want to investigate this for you.
    If you don't mind, I'll need to send you a private message to pass security.
    If you can check your logo at the top right of your screen, that would be great.
    Gareth_L
    • arlowood44's avatar
      arlowood44
      HI Gareth
      I responded with the security details you requested.
      Have you been able to investigate the problem I have?
      Many thanks
      Walter
