Dunker67's avatar
Dunker67
Not taking incoming calls
Is there an own outage in IP3 post code area for land lines? Am unable to receive calls but can make calls.
    Have you used the /check-services/   function to check for problems in your area? You can also a run a test on your equipment from there.
    If nothing is showing  you could also try the automated Service Status number  0800 561 0061.  This often gives details of more local issues down to postcode level.
  • Daniel_Et's avatar
    Daniel_Et
    Hi Dunker67, thank you for your post.
    We're sorry to hear about the problem you're having 😔
    If following the advice provided by newapollo hasn't given clarity on the situation, have you tried all the suggestions in this article here?
    Regards,
    Daniel
