ctafield's avatar
ctafield
Landline not ringing for incoming calls anymore
For some reason incoming calls do not ring anymore. Our phones aren’t on mute or privacy mode. They’re plugged into the wall (not yet been migrated over the hub).
Just tried a different landline phone and same thing.
If we call from our mobile and press the answer button on the landline it does actually connect but never rings out.
Used to work fine but stopped a month or so ago. Any ideas please?
  • Hi.  I have just joined this Community because I am experiencing the same issue as @Ayisha_B
    My landline doesn't ring when there's an incoming call yet the display will tell me there's a call.
    My sister can call me and I can pick up her call when the display shows me she's calling, but the handset will not show how long the call is going on for like it used to.
    I have installed brand new cordless handsets today and I have the same issue.
    Do I need an engineer to come out?
  • In case anyone else stumbles on this thread with the same problem. It turned out that our phone line had been switched over to digital but it didn't work. No one told us we were being switched over, and no one had bothered to check if it still worked.
    We've now been switched back to analogue. So, not a fault as such.
    • munrobasher's avatar
      munrobasher
      Up to speed
      Isn't that a temporary solution as analogue is been turned off soon.
      • Muhammod_I's avatar
        Muhammod_I
        This is correct as customers that are still on the traditional phone line will have to make the transition to the digital line once this is available for them.
        We understand that this isn't to everyone's liking as a lot of customers still prefer their original landline however this is a change that is being implemented by every service provider so no matter who you're with, they will also require you to use your phone line through the hub at some point.
        If you would like further support regarding this, please don't hesitate to reach out.
        We're always here to help 🙂
    • Ayisha_B's avatar
      Ayisha_B
      Thank you for the update ctafield and our sincere apologies you weren't informed of the migration.
      If we can help with anything else, please let us know.
  • HI ctafield,
    Thanks for your post, welcome to the Community Forums!
    Sorry to hear your landline doesn't appear to be ringing when you receive incoming calls.
    As you've tried a new handset without any success, it's likely that this is due to a fault called a 'ring trip' and will require a home engineer visit to resolve 😊
    I've dropped you a private message so I can take your details and arrange this with you.
