Soctty123's avatar
Soctty123
10 months ago
Home Phone line problems. No phone connected. 999 calls made from my line, not by me.
I have a home phone line with Virginmedia, but do not have a phone plugged in.
In my last bill I had call charges, which isn't possible as I don't have a phone connected, and indeed don't even have a home phone to connect.
I've tried up contact Virginmedia, but it's impossible due to the awful automated service.
Today, I had a visit from the police to tell me they'd received a 999 call from my home phone, which it's not possible.
I really need to speak to someone at Virginmedia to sort this out.
  • Hi Scotty123
    Thanks for posting and welcome to the community. Sorry to hear of this dispute. We can assist via PM. The process is to book an engineer visit to check any Crossed Lines, any call charges if found would indeed be credited back but if nothing found, a call out fee of £25 would apply.
  • goslow's avatar
    goslow
    We have seen reports of this before on here, inc. calls to 999.
    Does your phone connect to a traditional telephone wall socket or via the back of the VM hub?
    You should try to borrow a phone and plug it in to test the line. Chances are it is not working and is in some kind of fault condition.
      Yes, been there.  Many years ago I had this problem and despite 3 engineer visits it was never resolved.  Phantom calls at all times of the day and night. In the end I just cancelled the phone line and took the hit .
    • Soctty123's avatar
      Soctty123
      Connection is a wall socket. Haven't had an actual telephone for years though - nothing plugged in there. I don't know anyone with a home phone unfortunately.
      • goslow's avatar
        goslow
        A connection via a wall socket does lend itself more easily to a 'crossed line'.
        The pattern that is often repeated on here is that the customer does not use the landline and has no phone plugged in. At some point a fault occurs, or the line is disconnected, but the customer has no idea of this as the line is not in use and never checked or tested. The faulty/disconnected line starts generating call costs or registering calls to 999 etc.
        You are now in a somewhat adversarial situation with VM who will be keen to recoup call costs from you.
        Prior to the VM visit you should test the line and see if you have dial tone and can make calls in and out. The line may be totally dead or may be part working.
        Without doing any verification yourself, you are placing total trust in whatever judgement the VM tech comes to as you won't know if the line was working or not prior to the visit.
        I no longer have a landline but I keep a very simple gondola-type handset available for whenever I am asked to help anyone else with phone testing.
        Something like this
        https://www.amazon.co.uk/VTech-CD1100-Trimstyle-compatible-mountable/dp/B0CCDG5F7D
        sub-£10 is suitable. You could test with that.
        You should also log in to the VM hub and confirm that telephony is disabled on there.
        If you do that before the VM tech comes you will then be in a position to compare with whatever the VM tech tells you the problem is.
        While you continue to pay for a VM landline, you should occasionally plug a phone into the line and test it is working and you can call in and out.
        Some of the past 'phantom call charge' topics on here have dragged on and on for months and have involved £100s of pounds in call charges and hours wasted in comm's with VM to try to resolve so it is in your own interests really to keep an eye on the operation of your VM landline, even if you intend to make no use of it at all.
    It's one of the quirks of VM bundles.  Like you I never had anything plugged into the wall socket, but one day these calls just started to appear.  Odd numbers, very short duration, all different times even when no one was at home.  Despite 3 engineers it was never resolved.  To get rid of the problem I removed the phone from the VM package, but it did cause the price to rise a bit.  Since then, anytime I'm with VM, I've only ever get Broadband, no phone and no TV.
    Well that's me told off ....   ;-)
