Blonkster's avatar
Blonkster
2 days ago
Why the sudden and regular ping spikes?
What could be causing these regular ping spikes as seen in BQM?
All was fine until around 1900 on 16.12.2025
Super Hub 3 in modem mode with an Asus router
[removed - image/personal info]
prior to this date the pings were good
Pinging a remote site (bbc.com) from a command prompt is typically under 20ms. but my tests may not be coinciding with the spikes
TIA
Ian
  • legacy1's avatar
    Could be a update on the Asus router?
    If you copy your router WAN MAC to PC NIC you can change over with your PC to hub and allow ICMP inbound on firewall to setup a new BQM for checking.
    • Blonkster's avatar
      Blonkster
      Thanks, I'll look into that.
      I did try reverting the Hub back to hub mode, but it doesn;t accept WAN pings :-(
      Also, thanks to admin for removing the images, I didn't spot the small text IP addresses.
        You need to allow the Hubs firewall to respond and also in Router mode the WAN IP is different.
