SteveyW123's avatar
SteveyW123
5 months ago
Regular dropout of WiFi and Modem Reboot
For the past few weeks, my WiFi drops regularly and the modem occasionally reboots. The router log shows multiple entries for the following. Does this require an engineer visit as I have read?
SYNC Timing Synchronization failure - Failed to acquire
QAM/QPSK symbol timing;;CM-
  • Kath_P's avatar
    Kath_P
    4 months ago
    Hi SteveyW123,
    We're sorry to hear you're having issues with your WiFi connection and disconnections. Checking things here, there is no open fault affecting you. The hub is looking good in terms of power and signal levels however we can see quite a high number of disconnections.
    We won't be able to fix this remotely so I would like to arrange for an engineer to come to take a look at this for you.
    I just need to confirm the address to ensure we are booking the visit on the correct account. I have sent you a direct message to allow us to do this with you in a private space. Just click on the little ✉ at the top right-hand side of the page to access your inbox. 😊
  • jbrennand's avatar
    Post up all of the hub data...
    just copy/paste the normal  “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables in the Downstream tab, the 2 in the Upstream tab, &  the Network Logs pages.  Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
    Also, just check for a known fault on the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues and fix estimates, down to street cab/ postcode level.
    • SteveyW123's avatar
      SteveyW123
      Downstream
      1347000000640QAM 25627
      2139000000639QAM 2561
      3147000000639QAM 2562
      4155000000640QAM 2563
      5163000000640QAM 2564
      61710000005.940QAM 2565
      7179000000639QAM 2566
      81870000006.139QAM 2567
      91950000006.239QAM 2568
      102030000006.239QAM 2569
      112110000006.340QAM 25610
      122190000006.240QAM 25611
      132270000006.240QAM 25612
      142350000006.140QAM 25613
      15243000000640QAM 25614
      162510000005.939QAM 25615
      172590000005.939QAM 25616
      18267000000639QAM 25617
      19275000000640QAM 25618
      20283000000640QAM 25619
      212910000006.140QAM 25620
      222990000006.140QAM 25621
      233070000006.140QAM 25622
      24315000000639QAM 25623
      253230000005.839QAM 25624
      263310000005.640QAM 25625
      273390000005.840QAM 25626
      28355000000640QAM 25628
      29363000000640QAM 25629
      303710000006.139QAM 25630
      313790000006.239QAM 25631
      323870000006.139QAM 25632
      Channel
      Locked StatusRxMER (dB)Pre RS ErrorsPost RS Errors
      1Locked4000
      2Locked3900
      3Locked3900
      4Locked4000
      5Locked4000
      6Locked4000
      7Locked3900
      8Locked3900
      9Locked3900
      10Locked3900
      11Locked4000
      12Locked4000
      13Locked4000
      14Locked4000
      15Locked4000
      16Locked3900
      17Locked3900
      18Locked3900
      19Locked4000
      20Locked4000
      21Locked4000
      22Locked4000
      23Locked4000
      24Locked3900
      25Locked3900
      26Locked4000
      27Locked4000
      28Locked4000
      29Locked4000
      30Locked3900
      31Locked3900
      32Locked3900
      ChannelChannel Width (MHz)FFT TypeNumber of Active SubcarriersModulation (Active Profile)First Active Subcarrier (Hz)
      159944K1840QAM 40961108
      Channel IDLocked StatusRxMER Data (dB)PLC Power (dBmV)Corrected errors (Active Profile)Uncorrectable errors (Active Profile)
      159Locked07.814597757770
      SteveyW123
      Upstream
      ChannelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID
      06030000033.55120QAM 649
      153700000345120QAM 6410
      246200000345120QAM 6411
      33940000033.55120QAM 6412
      43260000034.35120QAM 6413
      523600000345120QAM 6414
      ChannelChannel TypeT1 TimeoutsT2 TimeoutsT3 TimeoutsT4 Timeouts
      0ATDMA0000
      3ATDMA0000
      4ATDMA0000
      5ATDMA0000
        SteveyW123
        Logs
        TimePriorityDescription
        17-11-2025 15:53:26warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=0c:11:67:02:5b:21;CM-QOS=1.1;CM-VER=3.1;
        17-11-2025 15:42:22noticeREGISTRATION COMPLETE - Waiting for Operational status
        17-11-2025 15:42:16warningREG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=0c:11:67:02:5b:21;CM-QOS=1.1;CM-VER=3.1;
        17-11-2025 15:42:11noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=0c:11:67:02:5b:21;CM-QOS=1.1;CM-VER=3.1;
        17-11-2025 15:42:08warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=0c:11:67:02:5b:21;CM-QOS=1.1;CM-VER=3.1;
        17-11-2025 15:42:06noticeHonoring MDD; IP provisioning mode = IPv4
        17-11-2025 15:41:56criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
        17-11-2025 15:41:56criticalCable Modem Reboot because of - HW or Power-On Reset
        17-11-2025 15:12:07criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=0c:11:67:02:5b:21;CM-QOS=1.1;CM-VER=3.1;
        17-11-2025 15:12:05criticalCable Modem Reboot because of - unknown
        16-11-2025 21:15:25criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=0c:11:67:02:5b:21;CM-QOS=1.1;CM-VER=3.1;
        16-11-2025 21:14:05criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=0c:11:67:02:5b:21;CM-QOS=1.1;CM-VER=3.1;
        16-11-2025 21:13:47criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
        16-11-2025 19:16:54criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=0c:11:67:02:5b:21;CM-QOS=1.1;CM-VER=3.1;
        16-11-2025 19:16:19criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=0c:11:67:02:5b:21;CM-QOS=1.1;CM-VER=3.1;
        16-11-2025 19:16:19critical16 consecutive T3 timeouts while trying to range on upstream channel 1;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=0c:11:67:02:5b:21;CM-QOS=1.1;CM-VER=3.1;
        16-11-2025 19:16:15criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=0c:11:67:02:5b:21;CM-QOS=1.1;CM-VER=3.1;
        16-11-2025 19:16:13criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=0c:11:67:02:5b:21;CM-QOS=1.1;CM-VER=3.1;
        16-11-2025 19:15:45criticalNo Ranging Response received - T3 time-out;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=0c:11:67:02:5b:21;CM-QOS=1.1;CM-VER=3.1;
        16-11-2025 19:15:42criticalNo Ranging Response received - T3 time-out;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=0c:11:67:02:5b:21;CM-QOS=1.1;CM-VER=3.1;
        16-11-2025 15:02:27criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
        16-11-2025 15:02:27criticalCable Modem Reboot because of - unknown
        15-11-2025 20:36:17criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=0c:11:67:02:5b:21;CM-QOS=1.1;CM-VER=3.1;
        15-11-2025 20:36:17critical16 consecutive T3 timeouts while trying to range on upstream channel 5;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=0c:11:67:02:5b:21;CM-QOS=1.1;CM-VER=3.1;
        15-11-2025 20:26:18criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=0c:11:67:02:5b:21;CM-QOS=1.1;CM-VER=3.1;
        15-11-2025 20:26:09criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=0c:11:67:02:5b:21;CM-QOS=1.1;CM-VER=3.1;
        15-11-2025 20:26:09critical16 consecutive T3 timeouts while trying to range on upstream channel 0;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=0c:11:67:02:5b:21;CM-QOS=1.1;CM-VER=3.1;
        15-11-2025 20:26:07criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=0c:11:67:02:5b:21;CM-QOS=1.1;CM-VER=3.1;
        15-11-2025 20:26:07criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=0c:11:67:02:5b:21;CM-QOS=1.1;CM-VER=3.1;
        15-11-2025 20:26:04criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=0c:11:67:02:5b:21;CM-QOS=1.1;CM-VER=3.1;
        15-11-2025 20:26:03criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=0c:11:67:02:5b:21;CM-QOS=1.1;CM-VER=3.1;
        15-11-2025 20:25:58criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=30:67:a1:d0:29:ff;CMTS-MAC=0c:11:67:02:5b:21;CM-QOS=1.1;CM-VER=3.1;
      SteveyW123
      18-11-2025 16:03:02warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-;CMTS-M;CM-QOS=1.1;CM-VER=3.1;
      18-11-2025 15:51:58noticeREGISTRATION COMPLETE - Waiting for Operational status
      18-11-2025 15:51:52warningREG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-;CMTS-;CM-QOS=1.1;CM-VER=3.1;
      18-11-2025 15:51:47noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-;CMTS-;CM-QOS=1.1;CM-VER=3.1;
      18-11-2025 15:51:44warningDHCP WARNING - Non-critical field invalid in response ;CM-;CMTS-;CM-QOS=1.1;CM-VER=3.1;
      18-11-2025 15:51:42noticeHonoring MDD; IP provisioning mode = IPv4
      18-11-2025 15:51:31criticalCable Modem Reboot because of - unknown
      18-11-2025 15:51:31criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-;CMTS-;CM-QOS=1.1;CM-VER=3.1;
      17-11-2025 15:41:56criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-;CMTS-;CM-QOS=1.1;CM-VER=3.1;
      17-11-2025 15:12:07criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-;CMTS-;CM-QOS=1.1;CM-VER=3.1;
      16-11-2025 21:15:25criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-;CMTS-;CM-QOS=1.1;CM-VER=3.1;
      16-11-2025 21:14:05criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-;CMTS-;CM-QOS=1.1;CM-VER=3.1;
      16-11-2025 21:13:47criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-;CMTS-;CM-QOS=1.1;CM-VER=3.1;
      16-11-2025 19:16:54criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-;CMTS-;CM-QOS=1.1;CM-VER=3.1;
      16-11-2025 19:16:19criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-;CMTS-;CM-QOS=1.1;CM-VER=3.1;
      16-11-2025 19:16:19critical16 consecutive T3 timeouts while trying to range on upstream channel 1;CM-;CMTS-;CM-QOS=1.1;CM-VER=3.1;
      • Kath_P's avatar
        Kath_P
        Hi SteveyW123,
