thewickedpicket's avatar
Gigabyte speed issue
Hello
I recently upgraded to gigabyte from M500. I run the hub 5 in modem mode and use an ASUS router for WiFi.
the speeds I am getting are only slightly better than M500. Around 600 using the ASUS wired speed test facility. WiFi speeds are also only slightly better.
I installed the hub myself and I assume there is an issue somewhere with the connection coming into the house?  Can someone contact me about this?
  • legacy1's avatar
    test speed by wire not the speed test on router
    disable QoS/BWM on your router
    • thewickedpicket's avatar
      thewickedpicket
      Thanks QoS is disabled. And the speed test was the same when I installed the new hub and tested directly from it. The ASUS router also has a feature that tells you the speed it’s getting from the modem. It’s never been much above 600mb
  • Roger_Gooner's avatar
    Roger_Gooner
    You cannot get 600Mbps from M500, for that sort of speed you need at least M600.
