Stones1's avatar
Stones1
21 hours ago
Virgin Hub 3 constant red light
I have a Virgin hub 3 and it has a constant red light showing. I have gone through the help process of resetting the hub and going back to the default settings and letting it cool down. This has not solved the issue. When the hub restarts it starts with the Red light showing and does not change to any other colour.
Does it need to be changed because of this issue.
    If it is a Hub 3 and if the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly.
    If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
  • Is your network connection still working, if it isn't then the quickest way to get a hub replaced is by calling Virgin on 150 from a Virgin phone, mobile or landline, or 0345 454 1111 from any other phone to report a fault, or wait here for one of the forum team to pick this up which might be 2 to 3 day's.
