Error cs9993 on volume does not work
Stappo
Managed to pair with tv and all works fine including putting the tv onto standby! but it still does not let me control the volume with the 360 remote? Have tried rebooting, pairing and unpairing again and again , rebooted the 360 box still no joy. Very frustrating as having to use two remotes
16 REPLIES 16
Hi @Stappo,
Has the advice that's been offered here helped you to resolve this matter, or is the issue ongoing for you?
Zach - Forum Team
New around here? To find out more about the Community Forums, take a look at our FAQs!
No this has still not been resolved, very frustrating as was working fine until I downloaded the 360 “upgrade”
There is no option to manually enter? There are two boxes one for change tv set up and one for amplified devices. I click on tv box and it searches then comes up with the cs993 error every time ? Tried hundreds of times and same error every time?
Hi again @Stappo
There isn't a CS993 error code. Do you mean CS9993?
Edited:- checked thread title and it is error CS9993
The online fault page /tv-error-codes/tv-error-code/cs9993  suggests it's a known fault and VM are working hard to fix the issue, however I don't think that's the actual issue as normally when that error surfaces the forum has a large number of users with the same error code/message.
In the past when I've had the CS9993 error it's been due to the 360 box not recognising that it's connected to the internet. This has prevented me changing settings and accessing apps and catch up services. I normally find rebootng the 360 fixes this( which you've tried) although sometimes i need to also reboot the hub as well.
IIs your 360 connected to the hub by ethernet cable or wifi?
It's best to connect the 360 by ethernet cable if possibe, if not then if you aren't using one of VM's pods then it may be worth splitting the SSID and try connecting the 360 box to the 2.4Ghz  band
Dave
No it has not been resolved. Is there any update on when it will be resolved?
artyrambler
I get the same error code and my TV  is Blaupunkt
Hi @Stappo, thank you for your response.
I can see you've spoken to the team since your latest post. Are you any further forward with this?
If not, have you tried following the latest advice provided by @newapollo?
Regards,
Daniel
