Seepod's avatar
Seepod
3 years ago
Wifi Parental/scheduling controls on hub 5
I’ve discovered it’s not possible to schedule downtimes for the hub 5 to prevent teenagers sneaking about at night trying to access internet from laptops and gaming consoles after they’re supposed to have gone to bed. Can anyone tell me how easy it is to replace the router with a superior one that we can control from an app, and what would be a good one to buy. Thanks!
  • Kain_W's avatar
    Kain_W
    Hi Seepod,
    Thanks for your post and welcome ot the community.
    Many apologies for the issues faced, can I ask has the parental controls been switched on indefinitely at all?
    Let us know,
    • Seepod's avatar
      Seepod
      Do you mean parental controls on the router? I didn’t know there were any to be hi eat. I can see that it’s possible to manually pause a device from having wifi access but I need to be able to schedule it so that it happens automatically.
      • Zoie_P's avatar
        Zoie_P
        Hi Seepod,
        Thank you for your reply, do you have our connect app at all? From this, you can pause device connections on here, you cannot set up timers on this, but I know some devices let you set up play/usage timers, I have one for my son on his iPad and PlayStation. Below are links for different consoles and parental timers 🎮:
        PlayStation
        X-box
        Nintendo Switch
        And here are other devices 📱:
        Apple
        Samsung
        Google
        HUAWEI
        Our parental controls do not have timers but will restrict certain sites that are not kid-friendly, you can find more about this 👉 here
        In regards to a superior hub, our hub 5 is the latest model, I can see however, that you are having some dropouts, which we can get a tech to come out and look at, I will drop you over a PM, and we can get this looked into for you if you wish, just keep an eye out for the little envelope 👀📩
        Zoie
