Virgin ultra HD and TNT sports Ultimate
Bid1
Hi all
on virgin stream,  virgin ultra hd and tnt sports ultimate isn’t broadcast in 4k on virgin stream.
when I select tnt sports ultimate it’s changes my picture to HLG.
1 ACCEPTED SOLUTION
Accepted Solutions
Roger_Gooner
HLG only comes with UHD broadcasts and it's reasonable to believe that UHD also only comes with UHD streams. As you have HLG I believe you are getting UHD streams from TNT Sports Ultimate.
Hub 5, TP-Link TL-SG108S 8-port gigabit switch, 360
My Broadband Ping - Roger's VM hub 5 broadband connection
9 REPLIES 9
Bid1
Any suggestion anyone? Thank you.
Roger_Gooner
If a stream like TNT Sport Ultimate has HDR, as it does for broadcast channel, it will be HLG.
Hi @Bid1
The picture format may be due to your Stream box settings, or your actual TV settings.
On the Stream box you need to have UHD set up under Settings > Audio & Video > HDMI resolution 4K.
On my TV the TNT Sports Ultimate (CH 531) and the Sky Sports UHD channels on 532 to 535 are all  broadcast in 4K HLG HDR
You need to pay extra for the Sky Sports UHD channels, however the TNT Sports Ultimate channel is included in the TNT subscription price.
Dave
The do's and don'ts.
Bid1
Thank you for your response.
I get the hlg logo coming on the screen. But when you press info on the virgin remote control. It’s should info days HD and Dolby sounds sign next to it.
My apologies @Bid1
I'm not sure what you're advising in your latest post.
Are you saying when you click on info, the information is wrong in some way?
Here to help 🙂
Virgin Media Forums Agent
Carley
Bid1
Yes. It say HD instead of 4K?
Okay, did you manage to go into your TV settings to see if anything is being changed at all?
Matt - Forum Team
New around here?
Bid1
Virgin ultra uhd is not in uhd and just in hd. My setting is in 4K etc
Roger_Gooner
