ccscot22's avatar
ccscot22
Wired connection slower than WiFi
New to Virgin, got 1gb package with Hub 5. Got my PC sitting right next to router and using wired connection. I'm only getting half the speed compared to the WiFi. Thought it was because I had cat5e cable, upgraded it to cat 7 and it's made no difference. Is this normal?
    What link speed does the Hub 5 and the PC report for the network cable connection ?
    Share screen shots of speed tests for both the Wi-Fi and the network cable.
    • ccscot22's avatar
      ccscot22
      first one is pc with wired connection, 2nd is my phone on wifi
        If it is a Windows PC, boot into "Safe Mode with Networking Support" and retest the Samknows.  Or, boot with a Linux ISO and retest.  As the Hub is getting the full 1Gb, the issue points to your PC as the bottleneck?
