Upload speed capped at 50 Mbps
NickLibra
Hello, I have a 1 Gbps download speed but my uplaod speed is capped at 50 Mbps. I called customer service and they said that it should be around the 400 amd they don't know what the issue is. They said that they will send a technitian but not for another 3 weeks. Is there anything that can be done from my side for this to be fixed? Anyone else has the same issue?
9 REPLIES 9
Upload speed on 1GB is only 100Mb, not 400.  There is a 1Gb symmetrical option, but that's only on XGS-PON in nextfibre areas.
The issue is usually someone at VM has loaded the wrong speed profile and that can be seen
in the Hub Menu >> Router status >> Configuration tab
The main internet profile will have Downstream & Upstream  entries called something like "Max Traffic Rate",
the figures in our Hub is in bits per second.  The Upstream figure should be at least 104,000,000 for a 100Mb/s upstream profile,  if it is more like 55,000,000 that is a 50 Mb/s upstream profile.
If this is the problem, an engineer visit will be a total waste of time.
That's it. In the upstream it has 53500000. How can I change that?
I will be happy with 100 Mbps of upload. I just need more than 50 but that is all I get.
Call it in as a fault on 0345 454 1111/ 150.
Cancel VM here
Complain to VM
here
Demand compensation from VM here
Demand your call recordings here
Monitor the state of your VM connection here
VM need to explain why they are not honouring the advertised 10:1 Downstream to Upstream ratio
for this customer's 1Gb/s connection.
It is worth knowing VM Hubs re-load the connection profile every time after power off / on,
or when a Reboot is commanded from the Hub's menu.   Pressing the reset button is not needed.
NickLibra
I call VM yesterday after a long call they said that they sent an update to my router and that after a few hours I was gonna see the upload rates going up. Still no change this morning. Calling them again now. They did say that a technitian is not needed.
Normally VM make the new profile available, and it is not loaded until the customer Reboots their VM Hub.
Hi NickLibra,
Thanks for your post and a big welcome to the Community. It's great having you on board with us.
We're sorry to hear you're having issues reaching your maximum upload speed.
We'd love to take a look in to things but have been unable to locate you on our systems using your forum credentials. 🙁 We will need to confirm some information with you in order for us to proceed with checks.
I have sent you a direct message to allow us to do this with you in a private space. If you are using a PC/Laptop then you can just click on the little ✉ at the top right-hand side of the page to access your inbox. If you are on a mobile/tablet device then instead click on the little circle icon in the top right then select 'Messages'. 😊
Kath_F
