on 16-05-2024 18:24
I have two issue. 1 my broadband speed is very fluctuating between 5mbps and 75mbps. It has more than 300mbps. 2 my VM Connect does not find Hub3, which was working properly before. I have done all required resolving steps like restart Router, removed and reconnect cable but no luck.
Please guide me to resolve issues.
Thank you
on 16-05-2024 21:59
How are you measuring the speed? On what devices, and how are they connected to the Hub? Only ethernet connected speeds are guaranteed by VM.
The best speed check is at https://www.samknows.com/realspeed
Post the results here.
