Slow Broadband
TeamFergus
My broadband has been slow for the last month. Please can someone help me to determine the best solution. It was restarted last week.  Upstream Downstream Network log and broadband monitor below.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/7f15c3139bc70beb0dc8233a488ce525b5...
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
242750000
0.9
40
256 qam
14
2
138750000
1.2
40
256 qam
1
3
146750000
1.7
40
256 qam
2
4
154750000
1.9
40
256 qam
3
5
162750000
1.9
40
256 qam
4
6
170750000
1.7
40
256 qam
5
7
178750000
1.7
40
256 qam
6
8
186750000
1.5
40
256 qam
7
9
194750000
1.2
40
256 qam
8
10
202750000
1.2
40
256 qam
9
11
210750000
1.2
40
256 qam
10
12
218750000
1.2
40
256 qam
11
13
226750000
1.2
40
256 qam
12
14
234750000
1
40
256 qam
13
15
250750000
1
40
256 qam
15
16
258750000
1.2
40
256 qam
16
17
330750000
0.7
40
256 qam
25
18
338750000
0.9
40
256 qam
26
19
346750000
0.7
40
256 qam
27
20
354750000
0.7
40
256 qam
28
21
362750000
0.7
40
256 qam
29
22
370750000
0.5
40
256 qam
30
23
378750000
0.7
40
256 qam
31
24
386750000
0.4
40
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.3
80
0
2
Locked
40.3
43
41
3
Locked
40.3
67
4
4
Locked
40.3
40
0
5
Locked
40.9
33
0
6
Locked
40.9
27
0
7
Locked
40.9
28
0
8
Locked
40.3
58
0
9
Locked
40.3
61
0
10
Locked
40.9
77
0
11
Locked
40.3
69
0
12
Locked
40.3
59
0
13
Locked
40.3
62
0
14
Locked
40.3
74
0
15
Locked
40.3
65
0
16
Locked
40.9
58
0
17
Locked
40.9
17
0
18
Locked
40.3
17
0
19
Locked
40.3
20
0
20
Locked
40.9
25
0
21
Locked
40.3
6
0
22
Locked
40.3
17
0
23
Locked
40.3
18
0
24
Locked
40.3
13
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
36600000
46.3
5120
64 qam
3
2
43100000
46.8
5120
64 qam
2
3
49600000
47.3
5120
64 qam
1
4
23600000
46
5120
64 qam
5
5
30100000
46
5120
64 qam
4
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
1
0
2
ATDMA
0
0
5
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
1
0
5
ATDMA
0
0
1
0
Time
Priority
Description
07/10/2024 14:16:36
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/10/2024 14:15:11
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/10/2024 04:46:3
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/10/2024 05:25:55
critical
03/10/2024 16:46:2
Error
02/10/2024 20:30:41
critical
30/09/2024 19:43:6
Error
29/09/2024 12:05:45
critical
29/09/2024 06:49:38
notice
NOTICE ATOM is restarted due to Kernel/oops panic as part of Self Healing Mechanism ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2024 19:37:57
critical
28/09/2024 14:34:18
notice
Unit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/09/2024 06:55:43
critical
26/09/2024 00:48:38
Error
22/09/2024 13:25:54
critical
22/09/2024 12:48:37
Error
19/09/2024 10:10:59
critical
19/09/2024 00:48:36
Error
17/09/2024 11:08:2
critical
17/09/2024 10:57:35
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2024 10:57:35
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
9 REPLIES 9
@TeamFergus
Your BQM link isn't working -  I think I've managed to work out the correct url
https://www.thinkbroadband.com/broadband/monitoring/quality/share/thumb/7f15c3139bc70beb0dc8233a488c...
Dave
What is the BQM reporting ? i.e. it looks very odd for a VM Hub.
The Hub stats look fine.
Speed test the service to the VM Hub + your device with the link below.
Once the test begins click on: Run full test to include: Latency, Jitter, Packet loss & Upload speed
Do share a screen shot of the Full test.
TeamFergus
 I hope that I’ve done this right. Thanks for your help
thats some tall grass for a BQM maybe you got the wrong IP?
I’ve done a new one on the basis you might be right.
its here -
https://www.thinkbroadband.com/broadband/monitoring/quality/share/e957d97a3193d6dac92440ef504c06edc9...
Any ideas on what’s wrong please?
The Samknows Realspeed test shows normal internet speeds.
jpeg1
Can't see anything wrong. Your speed test was on a mobile, so normal WiFi variations will apply.
- jpeg1
My name is NOT Alessandro. That's just a tag Virginmedia sticks on some contributors. Please ignore it.
Hi @TeamFergus
Welcome back to the community forums
Sorry to hear you're having issues with your internet at this time. We've checked the systems at our side and cannot see any issues that might be causing this.
Do you find that the issues only happens over one device or at one particular room/area of your come?
Here to help 🙂
Virgin Media Forums Agent
Carley
