PLEASE help, how do i get a wifi pod? i'm on new 1gb but bad wifi upstairr
bigguy283
Up to speed
as above,  i have tried to get a wifi pod, as my conections upstairs keep dropping, i looked at all the help pages, and it says you can order a FREE pod , if you click on my virgin media, my package, and in there will be a wifi max , link, to order your first pod!   . THERE IS NO LINK . here is what my package says for broadband:-
Volt Gig1 Broadband
You’re signed up to Volt benefits!
Exclusive benefits you get when your household is with both Virgin Media and O2.
My Volt benefits
• A broadband speed boost to the next available level (if you aren’t already on the fastest speeds you can get in your area)
• Up to three WiFi Pods at no extra cost if you find any pesky WiFi blackspots in your home
8 REPLIES 8
jpeg1
You must first demonstrate the need for the Pod, by using the VM WiFi app.
- jpeg1
My name is NOT Alessandro. That's just a tag Virginmedia sticks on some contributors. Please ignore it.
i have used the VM connect app, now what? as i said the connection is up and down like a fiddlers arms!!
i need a pod on my landing upstairs to get constant connection in upstairs bedrooms
jpeg1
Well I don't use the pods, but the app was supposed to allow you to order one.
If that isn't working, wait for a VM person to pick this up and offer to help.
- jpeg1
bigguy283
Up to speed
thanks for replying,  i will wait for help on here, it is so annoying, virgin media website is terrible  and so out of date, it even talks about using wifi connect app to find wifi hotspots while out and aboutm but of course they stopped all the wifi hotspots months ago !!!
jpeg1
Yes it is terrible, but at least it's consistent with the rest of VM's customer service.
- jpeg1
Hi @bigguy283 👋
Thanks for reaching out to us. Apologies for the issues that you are having with ordering a pod, we would need to bring you in for a private message to discuss this and resolve.
Please look out for the envelope on the top right of your web browser or if you are using a mobile device, it will be located under your profile icon.
Thanks.
Sabrina
Sent pm  thanks again
bigguy283
Up to speed
many thanks @Sabrina_B  you are a very helpull person 👍
