RL161's avatar
RL161
M250 broadband running at 34mbps
so over the last three days or so my pc seems to be running slow, especially when trying to access google related services, I had had same problem with two different browsers, and a laptop was equally slow.
I checked the broadband speed last night and it was recorded at 30mbps, this wasnt quite good enough to watch streaming tv without it buffering every few mins.
this afternoon its up to around 34mbps and this is in the cheshire Sk9 area
I have just done a router reset, and it now seems worse
less than 5mbps at 2.5ghz
15mbps at the 5ghz connection
I am not sure what it normally is, but I would say probably over 100mbps, whats the problem?
  • jbrennand's avatar
    What do you get when you connect the device directly to the Hub on an ethernet cable.
  • Hey RL161, thank you for reaching out and I am sorry to hear you are having some speed issues.
    I have taken a look and everything is look fine on our end.
    How has it been over the last few days, has it improved?
