on 22-02-2024 12:23
I’m struggling with speeds on my Amazon Firestick. A speed test via VM connect on my mobile behind the TV where the Firestick is gives a result of around 600. But a speed test run via the Firestick barely gets 30. I can also plug an Ethernet direct into the Firestick and it’s even slower with that.
Is there anything I can do to achieve the speeds I’m getting on my phone via the Virgin app?
thanks for any help
Answered! Go to Answer
on 22-02-2024 12:49
on 22-02-2024 12:49
on 22-02-2024 14:05
Thank you for the info. I'm still puzzled with the slow speeds though. I'm flummoxed as to why?
on 22-02-2024 16:06
Is the firestick's ethernet port only 10/100 - and not 1GB ?
on 22-02-2024 16:14
Get a better wifi router with 1Gb ports and use hub in modem mode
