Northesk's avatar
Northesk
Upgraded to Gig1 but max speed only 500Mbps
Hello guys,
Some info for you. Just got Gig1 about 2 weeks ago. Using a Hub 5, modem mode with TP-Link Deco M4 for mesh wifi. I use wired connections for static machines like the desktop PC so I do all of my speed tests from there. I've notice that the Hub 5 will drop connection entirely but recover after a few minutes.
Speed tests vary from 350Mbps (Cloudflare) to 500Mbps (Ookla Speedtest). Gigabit switch capacities support a max of 900Mbps so should be seeing roughly that number. Hope someone is able to take a look at this info and give some advice on this. I reckon it's a bad coax cable. For info before upgrading I had a Hub 3 and it used to get several T3 timeouts per and but wasn't noticeably degrading my internet experience (it did hang on some occasions though). Hope someone clever can offer some advice.
I'll pop the Hub status tables on the posts below
Thanks very much!
  • OK I think I found the speed problem.
    It was the TP Link Deco app QoS settings. So Ookla speed tests now show 900down/100up which makes sense given I have gigabit switches when QoS settings were tweaked. Rebooting the Deco units seemed to fix it, but it took a few tries for it to work. Can't say I'm a fan of the app, it really sucks because settings don't get saved. Oh and apparently you can't really switch QoS off so I just set it to a value of 1000/1000 and it appears to be ok.
    Don't know about the connection dropouts still, that problem doesn't look fixed to me so I'll report back later (and see if I can get the BQM graphs to show).
  • Cable Modem Status
    Item    Status    Type
    Cable Modem Status    Online    DOCSIS 3.0
    Primary downstream channel    Locked    SC-QAM
    Channel Overview    Downstream    Upstream
    DOCSIS 3.0 channels    31    5
    DOCSIS 3.1 channels    1    1
    3.0 Downstream channels
    Channel    Frequency (Hz)    Power (dBmV)    SNR (dB)    Modulation    Channel ID
    1    370000000    7.5    42    QAM 256    2
    2    362000000    7.6    43    QAM 256    1
    3    378000000    7.3    42    QAM 256    3
    4    386000000    7.1    42    QAM 256    4
    5    394000000    7.1    42    QAM 256    5
    6    402000000    7.2    42    QAM 256    6
    7    410000000    7.1    42    QAM 256    7
    8    418000000    7    42    QAM 256    8
    9    426000000    6.8    42    QAM 256    9
    10    434000000    6.5    42    QAM 256    10
    11    442000000    6.1    42    QAM 256    11
    12    450000000    6    42    QAM 256    12
    13    458000000    6.2    42    QAM 256    13
    14    474000000    6.3    42    QAM 256    15
    15    482000000    6    42    QAM 256    16
    16    490000000    6    42    QAM 256    17
    17    498000000    5.9    42    QAM 256    18
    18    506000000    5.8    42    QAM 256    19
    19    514000000    5.8    42    QAM 256    20
    20    522000000    6.1    42    QAM 256    21
    21    530000000    6.4    42    QAM 256    22
    22    538000000    6.4    42    QAM 256    23
    23    546000000    6.1    42    QAM 256    24
    24    554000000    5.8    42    QAM 256    25
    25    562000000    5.5    42    QAM 256    26
    26    570000000    5    42    QAM 256    27
    27    578000000    4.6    42    QAM 256    28
    28    586000000    4.6    42    QAM 256    29
    29    594000000    4.9    42    QAM 256    30
    30    602000000    4.8    42    QAM 256    31
    31    610000000    4.7    42    QAM 256    32
    Channel    Locked Status    RxMER (dB)    Pre RS Errors    Post RS Errors
    1    Locked    42    0    0
    2    Locked    43    0    0
    3    Locked    42    0    0
    4    Locked    42    0    0
    5    Locked    42    1    0
    6    Locked    42    1    0
    7    Locked    42    1    0
    8    Locked    42    0    0
    9    Locked    42    0    0
    10    Locked    42    2    0
    11    Locked    42    2    0
    12    Locked    42    7    0
    13    Locked    42    4    0
    14    Locked    42    6    0
    15    Locked    42    7    0
    16    Locked    42    9    0
    17    Locked    42    9    0
    18    Locked    42    8    0
    19    Locked    42    7    0
    20    Locked    42    7    0
    21    Locked    42    3    0
    22    Locked    42    2    0
    23    Locked    42    1    0
    24    Locked    42    3    0
    25    Locked    42    4    0
    26    Locked    42    12    0
    27    Locked    42    26    0
    28    Locked    42    24    0
    29    Locked    42    23    0
    30    Locked    42    19    0
    31    Locked    42    17    0
    3.1 Downstream channels
    Channel    Channel Width (MHz)    FFT Type    Number of Active Subcarriers    Modulation (Active Profile)    First Active Subcarrier (Hz)
    33    94    4K    1840    QAM 4096    1108
    Channel ID    Locked Status    RxMER Data (dB)    PLC Power (dBmV)    Corrected errors (Active Profile)    Uncorrectable errors (Active Profile)
    33    Locked    41    1.4    865769612    7415
    3.0 Upstream channels
    Channel    Frequency (Hz)    Power (dBmV)    Symbol Rate (ksps)    Modulation    Channel ID
    0    49600000    38.8    5120    QAM 64    7
    1    43100000    38    5120    QAM 64    8
    2    36600000    38    5120    QAM 64    9
    3    30100000    38.3    5120    QAM 64    10
    4    23600000    38    5120    QAM 64    11
    Channel    Channel Type    T1 Timeouts    T2 Timeouts    T3 Timeouts    T4 Timeouts
    0    ATDMA    0    0    0    0
    1    ATDMA    0    0    0    0
    2    ATDMA    0    0    0    0
    3    ATDMA    0    0    0    0
    4    ATDMA    0    0    1    0
    3.1 Upstream channels
    Channel    Channel Width (MHz)    Power (dBmV)    FFT Type    Modulation
    12    10.4    34.2    2K    QAM 256
    Channel    Channel Type    Number of Active Subcarriers    First Active Subcarrier (Hz)    T3 Timeouts    T4 Timeouts
    12    OFDMA    208    74000000    18    0
    General Configuration
    Network access    Allowed
    Maximum Number of CPEs    3
    Baseline Privacy    Enabled
    DOCSIS Mode    3.1
    Config file    cmreg-vmdg660-bbt076+voc-b.cm
    SFID    21034
    Max Traffic Rate    1230000450 bps
    Max Traffic Burst    42600bytes
    Min Traffic Rate    0 bps
    SFID    21036
    Max Traffic Rate    128000 bps
    Max Traffic Burst    3044bytes
    Primary Upstream Service Flow
    SFID    21033
    Max Traffic Rate    110000274 bps
    Max Concatenated Burst    42600bytes
    Scheduling Type    Best Effort
    SFID    21035
    Max Concatenated Burst    1522bytes
    Time    Priority    Description
    20-01-2025 20:35:21    notice    GUI Login Status - Login Success from LAN interface
    20-01-2025 19:11:44    critical    Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    20-01-2025 19:11:44    critical    16 consecutive T3 timeouts while trying to range on upstream channel 8;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    20-01-2025 19:10:36    critical    Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    19-01-2025 11:56:07    notice    REGISTRATION COMPLETE - Waiting for Operational status
    19-01-2025 11:56:02    warning    RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    19-01-2025 11:55:55    notice    DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    19-01-2025 11:55:52    notice    TLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    19-01-2025 11:55:50    warning    DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    19-01-2025 11:55:48    notice    Honoring MDD; IP provisioning mode = IPv4
    19-01-2025 11:55:45    critical    No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    19-01-2025 11:55:39    critical    SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    19-01-2025 11:55:38    critical    Cable Modem Reboot because of - HW or Power-On Reset
    18-01-2025 23:14:20    critical    No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    18-01-2025 23:14:14    critical    SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    18-01-2025 23:14:13    critical    Cable Modem Reboot because of - unknown
    18-01-2025 22:52:22    critical    No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    18-01-2025 22:52:15    critical    SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    18-01-2025 22:52:14    critical    Cable Modem Reboot because of - HW or Power-On Reset
    06-01-2025 17:01:18    critical    SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    06-01-2025 17:01:18    critical    Cable Modem Reboot because of - HW or Power-On Reset
    06-01-2025 16:47:24    critical    SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    06-01-2025 16:47:13    critical    No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    06-01-2025 16:46:53    critical    SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    06-01-2025 16:46:51    critical    No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    06-01-2025 16:46:36    critical    SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    06-01-2025 16:46:18    critical    SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    06-01-2025 16:46:17    critical    Cable Modem Reboot because of - HW or Power-On Reset
    06-01-2025 16:38:10    critical    No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    06-01-2025 16:38:05    critical    SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    06-01-2025 16:38:04    critical    Cable Modem Reboot because of - HW or Power-On Reset
    05-01-2025 21:53:28    critical    No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    05-01-2025 21:53:22    critical    SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
  • <a title="Broadband Ping" href="https://www.thinkbroadband.com/broadband/monitoring/quality/share/579091524d6ccdf247aa1b88bee38af888da6a81-18-01-2025"><img alt="My Broadband Ping - Virgin Media Gig1" src="https://www.thinkbroadband.com/broadband/monitoring/quality/share/thumb/579091524d6ccdf247aa1b88bee38af888da6a81-18-01-2025.png" /></a>
    <a title="Broadband Ping" href="https://www.thinkbroadband.com/broadband/monitoring/quality/share/6b2ff3bd02c940e2a5bd462fae5ccf72e85f799b-19-01-2025"><img alt="My Broadband Ping - Virgin Media Gig1" src="https://www.thinkbroadband.com/broadband/monitoring/quality/share/thumb/6b2ff3bd02c940e2a5bd462fae5ccf72e85f799b-19-01-2025.png" /></a>
    <a title="Broadband Ping" href="https://www.thinkbroadband.com/broadband/monitoring/quality/share/580092d9d0ba1ba17ae049b492a6cbc4fda88b57-20-01-2025"><img alt="My Broadband Ping - Virgin Media Gig1" src="https://www.thinkbroadband.com/broadband/monitoring/quality/share/thumb/580092d9d0ba1ba17ae049b492a6cbc4fda88b57-20-01-2025.png" /></a>
    • Cardiffman282's avatar
      Cardiffman282
      Community elder
      What a triumph this Html posting restriction is proving to be...
  • Are you using the 2.5Gbps port on the HUB?
    If you are, can you try one of the gigabit ports instead?
  • I would think you would need to switch back to router mode and connect directly to the Virgin hub using ethernet cable and do a speed test before they will do anything.
    " I use wired connections for static machines like the desktop PC"
    Wired at 1Gb/s to the first Deco M4 i.e. the one that is directly
    network cable connected to the VM Hub ?
    If No, wired to any other Wi-Fi linked Deco M4 is a PC using an external Wi-Fi adaptor.
    • Northesk's avatar
      Northesk
      For the PC it works like this: Hub 5 > Deco > Gigabit switch > Gigabit switch > Deco > PC. No wireless backhaul, all wired. I'll give it a go by just setting the Hub to router mode and connecting it to the switch.
    In Modem or Router mode ...
    Check in the Configuration tab of the VM Hub to see what speed profile is loaded,
    the Upstream & Downstream rate is shown in bits per second.   So for 1Gb/s we are expecting to see a figure a bit above 1000,000,000 in the Downstream max traffic rate.
    In Router mode this test link will show the speed to the VM Hub and at the device.
    Once the test begins click on: Run full test to include: Latency, Jitter, Packet loss & Upload speed.  The speed at the Hub should reflect your subscription.
    Thus test is also available as a mobile app called : Samknows Realspeed
