unhappyuser2804's avatar
unhappyuser2804
Dialled in
Best expected speed
Hi - What is the best, expected speed I should expect from my Volt M600 service? I’m currently getting between 250-275 Mbps which seems slow to me (though usable). There are no apparent problems in my area and restarting my hub has not helped. I’ve considered invoking my right to end my contact due to VM not providing my minimum speed, but I’m not sure I would be any better off with another provider, plus although my VM service is much slower than I pay for, there are very few complete breaks in service. What are other’s experiences?
    • unhappyuser2804's avatar
      unhappyuser2804
      Dialled in
      Thanks - great reply - problem solved - or at least identified. Realspeed showed over 600 Mps hitting my router, but only 300 Mps for my device, so the problem is inside my home.
