Frustration is now setting in! low upload in the evenings.
Rnash2002
Ok so i hope someone can help on here as Virgin are scratching there heads, after 6 engineers have been out, replaced everything even the line from the box up the street to my house im still getting very low upload speeds on an evening.
Since changing the line from the box up the street its got better but only to not go down to 0 upload and chuck me off my stream.
Its always in the evenings, worst being Fridays and it also seems to be when i get packet loss, this also seems to run till like 1 to 2am, when im not even on the internet.
One evening i pulled everything off my internet, went to bed and still was getting packet loss through to the early hours!
So what can it be? could it be that the line cant handle the 100 upload im paying for at peak times? this issue only seems to have started when i upgraded to the 1gig package with the hub 5.
Please help as i stream, i also get payed to stream and its not getting to the point that i dont want to stream on an evening because of this.
10 REPLIES 10
jpeg1
Set up a free BQM to monitor your connection, and post a live link here. It will take a day or two to build up a display.
- jpeg1
My name is NOT Alessandro. That's just a tag Virginmedia sticks on some contributors. Please ignore it.
jpeg1
Yes the packet loss is clear to see.
Can you post all the router stats on here?  Use text copy-paste, not screen shots as they are often difficult to see.
- jpeg1
Rnash2002
3.0 Downstream channels
13310000000.440QAM 25625
21710000000.140QAM 2565
31790000000.240QAM 2566
41870000000.340QAM 2567
51950000000.540QAM 2568
62030000000.440QAM 2569
72110000000.740QAM 25610
82190000000.741QAM 25611
92270000000.640QAM 25612
102350000000.541QAM 25613
112430000000.541QAM 25614
122510000000.441QAM 25615
132590000000.440QAM 25616
142670000000.440QAM 25617
152750000000.440QAM 25618
162830000000.540QAM 25619
172910000000.740QAM 25620
182990000000.540QAM 25621
193070000000.540QAM 25622
203150000000.640QAM 25623
213230000000.540QAM 25624
223390000000.540QAM 25626
233470000000.640QAM 25627
243550000000.640QAM 25628
253630000000.640QAM 25629
263710000000.640QAM 25630
273790000000.740QAM 25631
283870000000.740QAM 25632
293950000000.840QAM 25633
304030000000.740QAM 25634
314110000000.740QAM 25635
324190000000.740QAM 25636
1Locked401667
2Locked40757227
3Locked40490310
4Locked4010
5Locked4000
6Locked4000
7Locked4010
8Locked4100
9Locked4000
10Locked4100
11Locked4100
12Locked4100
13Locked40113129
14Locked4000
15Locked4000
16Locked4000
17Locked4000
18Locked4000
19Locked404866
20Locked4000
21Locked4000
22Locked4000
23Locked4016778
24Locked401080
25Locked40674
26Locked40874
27Locked40965
28Locked401064
29Locked40711180
30Locked4010
31Locked401069194
32Locked401084218
3.1 Downstream channels
159944K1840QAM 40961108
159Locked412.728307086160
3.0 Upstream channels
060300000355120QAM 641
153700000355120QAM 642
24620000035.55120QAM 643
33940000035.55120QAM 644
43260000035.55120QAM 645
523600000365120QAM 646
0ATDMA0010
1ATDMA0060
2ATDMA0030
3ATDMA0060
4ATDMA0020
5ATDMA001
0
Rnash2002
Need anything else?
jpeg1
All the levels are OK, there's nothing there to be corrected. The QAM settings OK as well. Too many T3 errors that are likely a result of the external packet loss and the consequent effect on your streaming.   It looks like there is nothing you can do but complain again.
- jpeg1
Roger_Gooner
Paste your network log here as well.
Hub 5, TP-Link TL-SG108S 8-port gigabit switch, 360
My Broadband Ping - Roger's VM hub 5 broadband connection
Rnash2002
10-07-2024 12:40:36noticeGUI Login Status - Login Success from LAN interface
09-07-2024 23:57:37criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
09-07-2024 20:21:58noticeGUI Login Status - Login Success from LAN interface
09-07-2024 02:23:44errorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
07-07-2024 17:22:30criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
06-07-2024 19:45:42noticeGUI Login Status - Login Success from LAN interface
05-07-2024 14:23:42errorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-07-2024 10:12:57noticeGUI Login Status - Login Success from LAN interface
04-07-2024 07:17:47noticeGUI Login Status - Login Success from LAN interface
03-07-2024 23:27:20noticeGUI Login Status - Login Success from LAN interface
03-07-2024 23:08:18noticeGUI Login Status - Login Success from LAN interface
03-07-2024 22:10:11noticeGUI Login Status - Login Success from LAN interface
03-07-2024 18:14:17criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
02-07-2024 11:04:20noticeGUI Login Status - Login Success from LAN interface
02-07-2024 02:23:41errorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-06-2024 18:40:07criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-06-2024 11:41:27warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
29-06-2024 20:50:20noticeGUI Login Status - Login Success from LAN interface
29-06-2024 20:49:55noticeGUI Login Status - Login Fail from LAN interface
29-06-2024 10:10:49noticeGUI Login Status - Login Success from LAN interface
28-06-2024 19:21:19criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
28-06-2024 16:05:37noticeGUI Login Status - Login Success from LAN interface
28-06-2024 16:04:39noticeGUI Login Status - Login Success from LAN interface
28-06-2024 16:02:19noticeREGISTRATION COMPLETE - Waiting for Operational status
28-06-2024 16:02:14warningDynamic Range Window violation
28-06-2024 16:02:14warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
28-06-2024 16:02:13warningREG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
28-06-2024 16:02:13warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
28-06-2024 16:02:13warningDynamic Range Window violation
28-06-2024 16:02:07noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
28-06-2024 16:02:00warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
28-06-2024 16:01:58noticeHonoring MDD; IP provisioning mode = IPv4
28-06-2024 16:01:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
28-06-2024 16:01:27criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
28-06-2024 16:01:27criticalCable Modem Reboot because of - Reboot Timezone Change
28-06-2024 15:59:14criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
28-06-2024 15:58:43criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
28-06-2024 15:58:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
28-06-2024 15:58:20criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
28-06-2024 15:58:19criticalCable Modem Reboot because of - pin-reset
Some of these were before the cable from house to box was changed as i was getting micro drop outs, these for me seemed to have stopped.
So this was like 10 minutes ago.
Screenshot 2024-07-10 at 12-38-11 Broadband Quality Monitor thinkbroadband.png
As you can see on the graph im getting packet loss right now and thats the speed test showing very low upload, so its not just at peak times i get it, the frustrating this is im still paying for the top package each month and have been for 4 months since this started!
Seems to be fairly common at the moment with VM.. I've never had issues with my speeds, packet loss in 5+ years.. but suddenly I've had nothing but issues.
I'm on the top package too and barely breaking 20mb upload and was getting consistently 100mbps+
Engineer has been out with no luck he said he thinks it's their side and will speak to networking team, seemed like it was fixed for 2 days then went back to being low and consistant packet loss.
