on 09-11-2023 00:56
My download speed is showing less than 1 mbps with speedtest.net and other tests. Upload still ~ 30mbps. It is still loading web sites,slow but doesn't feel that slow. Tried usual rebooting hub, PC, checking ethernet cables etc - no change. Tech over phone sent link and said fault with hub and to reset the hub. What effect will this have on my services as I have all my smart heating, other smart devices on network? Will it just automatically reboot all these?
Answered! Go to Answer
on 09-11-2023 01:09
Yeah, if you reset your hub, make sure you have the same wifi password setup as you do now. Any devices connecting via wifi should reconnect after the reset.
However, resetting the hub sounds like a last resort to me! Do you have any other devices you can Speedtest with, such as a mobile phone or tablet?
on 09-11-2023 01:09
on 09-11-2023 01:35
Faster when tested with my mobile phone at 25 mbps but still low. What does that mean. Wifi faster than ethernet. Cable fault?
on 09-11-2023 02:37
A few questions if I may...
on 09-11-2023 11:10
Well after fiddling around for a couple of days just checking stuff I have turned on PC this morning and it is up to 643 mbps and 42 mbps upload ! Don't know why unless VM responded to my logged call and did something at their end.
Anyway, thanks for the useful replies and all good, for now at least.👍
