dcweather
2 years agoDialled in
Download speed test less than 1mbps. Upload speed normal.
My download speed is showing less than 1 mbps with speedtest.net and other tests. Upload still ~ 30mbps. It is still loading web sites,slow but doesn't feel that slow. Tried usual rebooting hub, PC, ...
- 2 years ago
Yeah, if you reset your hub, make sure you have the same wifi password setup as you do now. Any devices connecting via wifi should reconnect after the reset.
However, resetting the hub sounds like a last resort to me! Do you have any other devices you can Speedtest with, such as a mobile phone or tablet?
