dejavus's avatar
dejavus
11 months ago
Download Speed is just under 300Mbps for a 1GB Connection
I Started with the 100Mb services several years back and have upgraded over the years and when i upgraded to 500Mbps I believe I was getting around 300Mbps but I have since upgraded to 500 and then to 1GB but my download has stayed at 300Mbps still.
I use my Hub5 in modem mode connected to a Draytek 2860 and I run all the test wired directly to the Draytek router.
Can anyone please help on how to get the full speed or at least very close enough.
Thanks in advance.
  • The 2860 is a great device but it's an older model and limited to 300Mbps.
    You'll need a later model if you want to take advantage of the faster WAN.
  • jpeg1's avatar
    jpeg1
    • dejavus's avatar
      dejavus
      Thanks for your Response and time, I erroneously thought it was Gb as well, well time for a new Router then!
  • legacy1's avatar
    having 1Gb ports is one thing having CPU do the throughput is another
