VM Media Hub Overheating. Replacement
three-kings
Hello,
My Virgin Media Hub (3), the White version, is overheating and causing frequent internet dropouts. The red indicator is on, indicating overheating.
I tried calling and booking an engineer, but the waiting times were too long. I work sporadic hours and am not always home.
Can a VM Mod arrange for a posted replacement Modem to be sent out?
Thx
3 REPLIES 3
Ashleigh_C
Hi there @three-kings
Thank you so much for you post and welcome back to the forums, it's great to have you here.
I am so sorry to hear that you are facing an issue with your Hub, to clarify when you say its overheating is the box showing a red light or is hot to the touch?
Is the Hub out and in a well ventilated area?
three-kings
Hi Ashleigh, Thanks for your reply. To confirm. My Hub is showing a red light, and it is quite hot to the touch. I reviewed the Hub guide about overheating and tried to leave it off and do a force reset via pinhole reset. It worked temporarily but then reverted to solid red light. The hub is in the living room, well-ventilated, and near a window.
Hey @three-kings Thanks for the reply.
We will look in to this for you.
I will send a private message.
Kind regards,
Ilyas.
Ilyas_Y
