on 10-02-2024 13:18
Hi - My Hub has had a constant red light for weeks & now no internet connection.
Tried all the usual steps of re-setting, checking connection cables, ensuring hub not over heating but still no internet access. Any advice welcome.
on 10-02-2024 14:57
If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
on 13-02-2024 15:17
Hi @msmsms13, thank you for your post.
We're sorry to hear about the problem you've been having 😔
In the first instance, can you please follow the below steps in the following order:
• Turn the power switch off on the back of the Hub
• Ensure the Hub is upright, in a well-ventilated location, and, if at all possible, out of direct sunlight
• Use the power switch to turn the unit back on
If after following the above steps the router doesn't boot back up after a few minutes, or the red light returns when it does, it'll need replacing.
Thank you for your support @Adduxi 👍
Regards,
Daniel
on 28-02-2024 15:39
Hi Daniel - I have tried the steps suggested in your post but I am still having issues. Sometimes broadband does not work at all & other times it is very very slow & pages time out before loading. Any suggestions?
on 28-02-2024 15:43
The red light remains on the router, constantly. This is the first time I have been able to respond due to the issues experienced.
on 01-03-2024 16:08
Thank you for that information msmsms13.
I will private message you now so we can look into this.
^Martin
on 07-03-2024 01:35
Hi Martin - problems are getting worse as I have been unable to log into my Virgin media account & not able to log into email even when I am at another location, using a different broadband connection. Is Virgin media online accounts & email servers down? I have been unable to login at any location.
on 10-03-2024 15:29
Hi @msmsms13,
I can see you are in PM already with Martin in relation to this matter.
Please do continue liaising with him there for further support.
