on 20-01-2023 17:06
Looking for an extension from my wall Virgin box to the Hub. Does Virgin do anything like this? This is just a straight connection cable and not the ethernet one
Answered! Go to Answer
20-01-2023 17:42 - edited 20-01-2023 17:44
@Dfountain24 wrote:Looking for an extension from my wall Virgin box to the Hub. Does Virgin do anything like this? This is just a straight connection cable and not the ethernet one
AFAIK, the longest pre-made coax lead VM supply is 3m (which they should be able to send you).
For anything longer you need a VM tech visit to custom-make a lead and test the connection. Flat fee of £25 for the tech visit.
on 22-01-2023 17:55
Hi Dfoundation24,
Thanks for your post and a warm welcome to the Community Forums.
As mentioned by goslow, we can send out up to 3M cables, or we can book in a chargeable Technician to attend your property and provide a custom-sized one.
Please let us know if either of those options are something you wish to do, and, if so, one of the team can drop you a private message to get this sent out/booked for you.
on 22-01-2023 19:18
Hi Reece,
Massive thanks for the response. A 3m cable would be amazing if you could arrange for this to be sent?
Many Thanks
on 24-01-2023 20:24
Evening Dfountain24 🙂
I've popped you over a private message to get a few more details from you (purple envelope, top right hand corner)
Alex_Rm
on 12-12-2023 11:55
@Alex_RM sorry for jumping in on this thread, could I get one of those cables sent out? Trying to move my hub from behind the TV where the socket is as WiFi signal is impacted but the provided cable wasn't long enough.
on 14-12-2023 13:12
Hi @benney,
I'm sorry to hear you need a bit of help with a longer cable. Have you been in touch with the team to arrange and sort this since your post? If not then please respond to the private message that I'll be sending to you shortly and we can proceed from there.
on 22-01-2024 12:06
Hello @Zach_R - I could also do with a longer cable, if it would be possible to send one? Thanks
on 24-01-2024 12:23
Hey @milkyway1,
We can certainly look into raising this through for you, for me to go about doing so, I will need to confirm some information from you via a private message which I will send to you now.
Joe
on 25-01-2024 17:56
Hi @milkyway1,
Thank you so much for messaging with us, glad I could order this for you. Please let us know how you get on 😊
Zoie
