30-11-2023 19:02 - edited 30-11-2023 19:47
So for the last few weeks I have been having major dropouts on my network, at first I thought it was the hub throttling as there are a few 2.4ghz iot on there. But after a few complete hub resets( pinhole reset) and leaving all my WiFi items disconnected the problem still remains. I have been onto VM a couple of times now and all they say is "our system says there's no fault" and then try upselling me a faster connection or WiFi booster to "fix my issue" . Which I know it won't as it's not a WiFi issues.
The problem is I am getting major network packet loss and it's making my connection unusable ( I am having to write this on my mobile data) I have setup a think broadband graph and as you can see it's bad, and seemingly getting worse. Got a few good hours today and thought we may be good but it's gone again
Using my playstation is a no go getting booted from servers every few minutes, making it impossible to use, and just General internet usage is abysmal having to sometimes wait upto 5 minutes for pages to eventually load
on 01-12-2023 15:11
Whatever it was, seems to have sorted itself out after 12 .....
on 01-12-2023 15:55
Seems to have which is weird as it has been bad for last few weeks , so I posted here and within 12hrs seems to be good again. Going to leave the monitor on for a while see if anything changes or if problem re appears.
I notice that I have only one upstream channel bonded but I see most others seem to have 4, 5 or sometimes more. Is that right ?
02-12-2023 13:41 - edited 02-12-2023 14:20
Check the automated service 0800 561 0061 for any known faults in your street.
The single upstream is not correct, the Hub is transmitting at a very high power to be received at the street cabinet, there should be 4 to 6 upstream channels connected all at a lower power level. This looks like a noise (SNR) fault.
Hub Signal Level Checks
Via http://192.168.0.1/ connect to the Hub in Router mode, do not login in, scroll down to "Check router status" Use http://192.168.100.1/ for a Hub in Modem mode
Using the Hub's "Check router status" tabs check the Downstream and Upstream power levels are in spec.
( If already logged in to the Hub menu, the same info is available at : Advanced settings >>> Tools >>> Network status )
Downstream Power Levels of -7 to +7 dBmV are preferred, +10dBmV is the max acceptable, with a SNR of 33dB or higher across all DOCSIS 3.0 channels. Rising error counts across many channels is a current service noise fault.
Upstream Power Levels of 35 to 49 dBmV are preferred, with QAM 64 Modulation mode across all four to six DOCSIS 3.0 channels. Seeing QAM 32/16/QPSK is a current service noise fault. Seeing less than four DOCSIS 3.0 channels is usually a signal level fault.
on 03-12-2023 00:48
on 03-12-2023 12:35
Yes, there is a fault for sure. You should have at least 4 US channels, all QAM64. VM will need to check this out and send a technician to fix it.
03-12-2023 12:57 - edited 03-12-2023 13:06
Was you downloading or uploading when this happened?
and when you have one channel is it the Ranged Upstream Channel listed in Status
03-12-2023 15:15 - edited 03-12-2023 15:23
No download or upload at the times it's bad , usually can't do anything and have to revert to mobile data everything just times out. And yes just one upstream channel as in first post. Trying to check now but it just gone bad again and can't get to the page ATM.
Will have to try for a fourth time tomorrow to get them to listen, all they say is there's nothing wrong even when it's bad as I'm on the phone to them
Managed to get to get page up.
1 49599930 51 5120 64 qam 1
1 ATDMA 0 0 37 0
on 04-12-2023 13:00
Yesterday evening from 3pm ISH untill after 1am ( we where in bed hours before that) and now from today around 12its bad again. This is getting ridiculous now. Basically making connections unusable. Tried phoning again this morning to be cut off 3 times. Had to stop to calm down. Going to try calling again now, hopefully they don't cut me off again
04-12-2023 15:02 - edited 04-12-2023 15:03
Finally spoke to a tech that actually seems to know something, all other techs have said there's no issues all is fine ect can't see fault. The tech I spoke to today says he can see an issue and that there has been 1952 disconnections in the last 30 days. Jeez that's an average of 67 disconnects a day. He made a few tests took some notes and arranged for a technician ho come tomorrow:) hopefully they actually turn up and can find the issues. Will update if they turn up .
