- Client62Alessandro Volta
The question needs to be asked & tested for a specific VM Hub.
- bm77Joining in
My question isn't tied to a specific Hub, just curious about the behaviour on any that feature the split SSID.
- Roger_GoonerAlessandro Volta
Assuming that a device does not support only 2.4Ghz, it will will automatically connect to the strongest available WiFi signal. All things being equal, a 5GHz WiFi signal is likely to be stronger than a 2.4GHz signal.
- bm77Joining in
I understand the the nuances between 2.4 and 5, that's not what I'm asking.
Maybe if I expand a little:
I have a phone that only has a 2.4 radio so I connect it to VM123456-2G.
I have a laptop that has both radios but for additional throughput, I connect it to VM123456-5G.
Can those devices connect to each other (presuming relevant firewall rules are in place)?
- vmrunreliableSuperfast
Yes.
Related Content
- 2 months ago
- 3 months ago
- 1 year ago
- 7 months ago
