- AdduxiVery Insightful Person
If this is a replacement Hub it can take several days for the Connect app "backend" database to catch up with new installs.
In the meantime, manage the Hub via the admin console http://192.168.0.1
The admin password should be printed on the bottom of the Hub.
- JuliengaonachTuning in
The connect app still doesn't work...I cleared the cache and data of the app, but still not working.
- Client62Alessandro Volta
Try to manage the Hub 4 via its admin menu at http://192.168.0.1/
- Megan_LForum Team (Retired)
Hi Juliengaonach,
Thanks for posting on our Community Forums about this issue with your Connect App not recognising your Hub.
The first thing to be aware of is you need to be connected to your Home Wi-Fi in order for the app to connect to the Hub. It won't allow the connection if you're on a different Wi-Fi network, Guest network on your own Wi-Fi, VPN, or mobile data. If this still doesn't help, try clearing the data within the Connect App. These steps will help you do that:
For your Apple device, if you're on iOS 15 then you can try this: Open Settings > Tap your name > Tap iCloud > Tap Manage Settings > Tap the Connect App > Tap Delete Data.
If you're on iOS 16 then just delete the app from your device, restart the handset, and then re-download the Connect App.For your Android device, you can try this: Open settings > Apps > Connect App > Storage > Clear data / Clear cache.
Let us know if this helps to resolve the issue.
Meg
Before you persist further with the VM Connect app for the Hub 4, make sure that you can use the Hub 4 menu.
If Hub4 menu fails at a a blank screen after the password is entered, the Hub 4 has a fault and the VM Connect app will not work + any VM Pods may be offline. This is an on going Hub 4 problem for VM to resolve.- JuliengaonachTuning in
I access the hub 4 settings after entering the hub password. I see my wireless and ethernet connected devices.
What should I do next?
- legacy1Alessandro Volta
Juliengaonach wrote:What should I do next?
if you don't know then do nothing🤔
Unless you have some special requirements I'd use the Hub 4 as it is without making adjustments.
Related Content
- 2 years ago
- 5 months ago
- 8 months ago
- 1 year ago
