Koeman
1 year agoTuning in
Problem connecting to work secure VPN
Hi all,
Recently upgraded to 1gb fibre so they have sent me a new Hub5. Since installing the hub5 I am unable to reach my work login.
I have spoken to the help desk at work, and they say it must be something virgin end.
If I use a mobile hotspot, it connects fine, just not when connected to the router.
It just says it cannot reach the page. Seems to work fine for my wife's NHS login, but not for my workplace.
Does anyone know how I could go about fixing the issue as work cannot help me currently
Yes, it's the IP Configuration for the Network setting, you just use a Manual DNS instead of Auto. However if your work is anything like my old place, you'll not be able to change this?
