Red light on hub
alovisi
@Lee_R and @Daniel_Et - I'm experiencing the same constant red light issue that started a few weeks back, although broadband has been running ok recently (apart from a wider outage a couple of weeks ago). Also been through all the troubleshooting steps.
I've noticed a bunch of very similar posts here recently, so have you checked if the red light is connected to a recent firmware update to the hub? If it is a hardware issue, could you please arrange a replacement our side. Please note that I have 2 pods connected and want to make sure that they pair correctly if a new hub is sent out. Thanks!
1 REPLY 1
Sabrina_B
Hi @alovisi 👋.
Thanks for reaching out to us. Apologies for the issues that you are having with the red light on your Hub, we would need to bring you in for a private message to discuss this and resolve.
Please look out for the envelope on the top right of your web browser or if you are using a mobile device, it will be located under your profile icon.
Thanks.
Sabrina
