on 10-02-2024 15:49
My hub 3 has a red light and it's been like that for a few weeks. In the past week, my connection keeps dropping and this happens all day. The connection is really intermittent and it's a nightmare as my devices keeps buffering to state Internet connection lost or reconnecting.
Rebooted the router,reset it via the pin too and issue remains. Any help is appreciated.
on 10-02-2024 16:09
If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you
on 13-02-2024 15:37
Hey Mo160191, thank you for reaching out and I am so sorry to hear this.
Please do try these steps;
• Then use the power switch to turn the unit back on. The Hub should now operate normally.
I will send you a PM in meanwhile.
Matt - Forum Team
New around here?
