on 13-01-2024 15:22
I have a steady red light on my V3 router box. I've tried all the resets as described in other posts, (reboot, reset, etc) and I still have the light. The box is NOT hot to the touch.
Any suggestions ?
on 13-01-2024 15:42
Hi @flames7607 👋 Thank you for your post and welcome to the Virgin Media Community 😀
In the first instance, we'd advise you to follow the below steps in the following order:
• Turn the power switch off on the back of the Hub
• Ensure the Hub is upright, in a well-ventilated location, and, if at all possible, out of direct sunlight
• Use the power switch to turn the unit back on
If you've followed the steps and the router isn't booting back up after a few minutes, or the red light returns when it does, it'll need replacing.
Regards,
Daniel
on 13-01-2024 15:56
Hi Daniel,
I've tried as you suggested, red light still comes back on.
on 14-01-2024 07:56
How do I arrange a replacement please ?
on 16-01-2024 09:43
Thanks for letting us know flames7607,
I've popped you over a private message to get a few more details from you.
Alex_Rm
on 17-01-2024 09:18
Thanks for joining me over private message flames7607,
Glad I was able to help 🙂 Pop back and let us know how the engineer visit goes.
Alex_Rm
on 21-01-2024 07:42
So, engineer has been, box changed, and all is good !
10/10 for the service I recieved
Thanks for all your help Alex
on 23-01-2024 11:46
Hi flames7607 👋
Thanks for the update. I'm glad to hear things are now back to normal after the Technician visit. If you need anything else, please do let us know, and we'll be happy to assist.
Cheers,
