Eupen71's avatar
Eupen71
Red Light on Hub3 wont go away
Hi - i have the permanent red light on my router which wont go away despite not being hot, resetting, using the apps to reset and turning off and on after resting
The advice seems to be here to order a new router but i cant find a way to do that online and contact customer services.
thanks
  • Ashleigh_C's avatar
    Ashleigh_C
    Hi there Eupen71
    I am so sorry that you are experiencing an issue with your Hub and thank you for trying the reset. I'd be happy to look into this with you via a private message and arrange an engineer visit to take a closer look.
    • babaganoosh33's avatar
      babaganoosh33
      I have the same problem. Constant red light on my hub3. I've reset it countless times but now the wifi is dropping in and out. It's space is not an issue. Looking at the number of posts going back years, this seems to be a common fault with the hub3 and I would like to arrange for this to be replaced - as many other users state - this is the only solution once this happens.
      • Zach_R's avatar
        Zach_R
        Hi babaganoosh33,
        Thank you for your post and welcome back to our community forums. We're here to help.
        I'm sorry to hear that you had a constant solid red light on your Hub 3. If you haven't done so already, please follow each of the steps below.
        • Then use the power switch to turn the unit back on. The Hub should now operate normally.
        If the issue remains after following the above then please respond to the private message that I'll be sending to you shortly and we can proceed from there.
