Red Light on Hub
Brettalt
My internet is working, but I've had red Light on router for some time now. I have tried everything: Turn off, Reset, check all connections etc and nothing has fixed.
Can I please have a new hub?
1 ACCEPTED SOLUTION
Accepted Solutions
lotharmat
Community elder
If it's a red light in Router mode as opposed to modem mode - VM need to swap out the hub asap as it is either overheating or thinks it is due to a faulty sensor!
If it were me, I'd call 150 (or 0345 454 1111) and tell them it is hot - they'll book a tech visit sharpish!
It is sad that offshore CS will only budge on this if you tell them it is hot - but unfortunately until proper training filters down - this is all we've got!
4 REPLIES 4
lotharmat
Community elder
Cheers for the advice lotharmat, appreciate it!
Natalie_L
Hi Brettalt,
Welcome to the community and thank you for posting.
I am sorry to hear you are experiencing an issue with a red light showing on your Hub, we will do all we can to help.
To look in to this further, I am going to pop you over a private message to take a few details.
This will be available via the purple envelope on the top right of this page.
Speak soon,
Nat
start your own new thread - say what Hub model you have
I do not work for VM. My services: HD TV on VIP (+ Sky Sports & Movies & TNT sport), x3 V6 boxes (1 wired, 2 on WiFi), Hub5 in modem mode with Apple Airport Extreme Router +2 Airport Express's & TP-Link Archer C64 WAP. On Volt 350Mbps, Talk Anytime Phone, x2 Mobile SIM only iPhones.
