ajcamg's avatar
ajcamg
Permanent red light on router
Hi. Similar to other participants on this forum, my router is displaying a premanent red light and has done for the past couple of weeks. Everything is working as it should - wi-fi, TV, phone all OK. I've re-booted the router 3 times, and all the green lights come on during the final process, but the red light stays on. Last time I re-booted, and mindful of comments on overheating, I left it for 30 mins to let it cool down, then turned it on. Same things happened. Some advice will be appreciated.
1 Reply
  • Hi ajcamg,
    Thanks for posting and sorry to hear you're having some issues with the hub.
    So I can get a few more details from you I've popped you over a private message.
    Alex_Rm
