11-02-2024 22:27 - edited 11-02-2024 22:30
Can anyone advise on how to fix packet loss, have been noticing packet loss during gaming recently and decided to check on the router status and BQM.
packetlosstest.com - preset "Counter strike 2" server set to United Kingdom
1 | Locked | 34.9 | 535144 | 0 |
2 | Locked | 33 | 239098048 | 0 |
3 | Locked | 29.1 | 1787864994 | 223615704 |
4 | Locked | 27.7 | 1468112227 | 902735719 |
5 | Locked | 28.1 | 1589549743 | 392137168 |
6 | Locked | 28.1 | 1216259856 | 224934880 |
7 | Locked | 32.2 | 149421041 | 24 |
8 | Locked | 34.3 | 15270017 | 0 |
9 | Locked | 37.3 | 9184 | 0 |
10 | Locked | 38.6 | 7697 | 0 |
11 | Locked | 37.6 | 9471 | 0 |
12 | Locked | 38.6 | 9164 | 0 |
13 | Locked | 37.6 | 13466 | 0 |
14 | Locked | 37.3 | 53535 | 0 |
15 | Locked | 35.5 | 681007 | 0 |
16 | Locked | 33.2 | 58942245 | 0 |
17 | Locked | 32.3 | 112718903 | 5 |
18 | Locked | 32.5 | 188379984 | 23765123 |
19 | Locked | 35.5 | 697475 | 0 |
20 | Locked | 37.6 | 11836 | 0 |
21 | Locked | 37.6 | 11912 | 0 |
22 | Locked | 36.3 | 28468 | 0 |
23 | Locked | 35.7 | 203801 | 0 |
I've seen the max ping spikes before but the packet loss looks like this one some days between 5-10% may have seen higher.
On the router pages it says "Internet(Partial Service (DS only))"
There are also Post RS errors as above. Upstream I think is ok, only 3 T3 timeouts, spread across 3 channels.
The network log also has Lost MDD timeout and RCS Partial Service
11/02/2024 22:19:38 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/02/2024 22:19:38 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
Let me know if I can provide anything else.
12-02-2024 15:58 - edited 12-02-2024 15:59
That is an awful connection... so first thing is to check for any “known" network faults in your location - Look in 2 places...
1) Try the “check service,”Area status webpage (https://www.virginmedia.com/help/service-status)
2) Then also Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues and fix estimates, down to street cab/ postcode level.
Report back on that
on 13-02-2024 17:51
Thanks for the reply
Checked the website all services have a green tick but there is a banner saying there will be work in the area in about 3 days time for 5 hours 1am 6am, for tv, broadband and phone, maybe that will help.
The phone line reports no issues.
on 14-02-2024 13:29
Hi @andrew89898, thank you for your post.
We're sorry to hear about the problems you've been having 😔
In order to discuss this further, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
Thank you for your support @jbrennand 👍
Regards,
Daniel
